Privacy Panels question
Post  agro on Thu 19 Sep 2013, 10:16 pm
Just wondering what would be the best stuff to get to put privacy panels on my doors?
What type of metal would be best?
Should i get them welded on or would a fiberglass panel be just as good?
Also want to get door handles and locks removed as well.
Re: Privacy Panels question
Post  fc59 on Fri 20 Sep 2013, 8:15 pm
im not sure what you mean by privacy panels for doors can you elaborate a bit more please
and as far as i know shaving door locks is still illegal unless the door still has a mechanical handel or pop button dont quote me on that
Post  panoz78 on Fri 20 Sep 2013, 8:53 pm
Privacy panels
I would do in fibreglass if I wanted to remove them at a later date,
In steel to be permanent .
Dean is right you can't remove door handles due to safety ,door locks you can.
Post  agro on Fri 20 Sep 2013, 10:39 pm
What i don't understand is the reason why you CAN'T remove door handles and locks???
Lets say your in an accident and the doors are locked from the inside...........The handle doesn't work on the outside, so why have the handles if they won't open the door???????????????????????
Post  panoz78 on Fri 20 Sep 2013, 11:02 pm
Yep it's stupid that way ,actually you can remove door handles ,
My son has done 2-3 minitrucks ,they have to be engineered and
you buttons on the outside to replace the handles .so when you push the button
the door opens ,don't know if they can be electric though.
Post  sinbin on Fri 20 Sep 2013, 11:21 pm
Handles and locks can go no problem but you must have a mechanical release on the exterior.
You just have to be creative!
You can also have these electrically operated but the mechanical system must override everything.
Post  agro on Sat 21 Sep 2013, 7:52 am
SOOOOOOOOOOOOOOOOOOOOOOO back in the day they had a push button on the inside of the door, i can put a mechanical push button in there and it should be o.k.????
Post  panoz78 on Sat 21 Sep 2013, 8:21 am
You need a mechanical button
on the out side.
Post  HBWC on Sat 21 Sep 2013, 12:49 pm
yes mechanical on the out side it can be hidden tho ie i know alot of hot rod guys use choke cables hidden under guards ect
mind you that may of changed as alot of new cars have electric door openers on the out side so look into it you may not need them
HBWC
Post  sinbin on Sat 21 Sep 2013, 2:37 pm
agro wrote:SOOOOOOOOOOOOOOOOOOOOOOO back in the day they had a push button on the inside of the door, i can put a mechanical push button in there and it should be o.k.????
Yes, that should be fine. Check with an engineer to be sure though.
Post  sinbin on Sat 21 Sep 2013, 2:40 pm
HBWC wrote:mind you that may of changed as alot of new cars have electric door openers on the out side so look into it you may not need them
That is a good point. If you can draw correlation with something already approved on the market then your chances of success improve massively. Find a car that does, tell/show the engineer and see if he is willing to sign off on it. They need to be able to relate the modification to the correct ADR.
