How do I turn an item off when I turn another on.
How do I turn an item off when I turn another on. Empty How do I turn an item off when I turn another on.
Post  master6 Sun 03 Aug 2014, 1:50 pm
I want to run a 240 volt radio in my shed, to create increased "background noise", and have it turn off automatically when I start my angle grinder.
How do I do this?
How do I turn an item off when I turn another on. Empty Re: How do I turn an item off when I turn another on.
Post  blur1 Sun 03 Aug 2014, 6:03 pm
you wont hear the radio when the grinder's going anyway, so just pretend in your mind that it's off. lol!
Post  master6 Sun 03 Aug 2014, 6:32 pm
blur1 wrote:you wont hear the radio when the grinder's going anyway, so just pretend in your mind that it's off. lol!
The radio was just an example.
I want to turn one appliance/tool OFF, when I start another one.
As another example, I might want my aircompressor to turn off when I start a drill.
Post  fc59 Sun 03 Aug 2014, 8:28 pm
Short of flicking a switch i cant help youi had the same problem i just got the power upgraded
Post  big rob Sun 03 Aug 2014, 10:40 pm
I'm sure it can be done, but you need to talk to an electrician. It could be as easy as a device that each appliance is plugged into, (or may be a bit of a real pain in the ar#e). A decent electrician would be able to point you in the right direction.
big rob
big rob
Post  master6 Mon 04 Aug 2014, 7:40 am
big rob wrote:I'm sure it can be done, but you need to talk to an electrician. It could be as easy as a device that each appliance is plugged into, (or may be a bit of a real pain in the ar#e). A decent electrician would be able to point you in the right direction.
Probably correct big rob. Question now becomes "where do I find a decent electrician?" I tried the electricians forum and found mostly idiots.
HOLD THE STONES PLEASE Very Happy
Joking...............I am sure that there are many clever electricians.................and I will find one Smile
Post  Rohan Mon 04 Aug 2014, 9:23 pm
Other options could be electrical wholesalers in case there's an off the shelf item that will do the job, and I find the local Jaycar store have some obscure gadgets.... Good luck.
Post  Rusty62TransAm Tue 05 Aug 2014, 12:26 pm
I've got my Bucket of Stones loaded and beside me!!  NoWay1
With the diversity in Electrical Work there is a diverse range of Electricians who specialize in certain areas of the Trade.
Nothing is Impossible, but Miracles do take a little longer.
Your Brief is lacking in detail and ambiguous.  Provide a clear and concise Scope of Works and you'll get some Positive Results.  There are a few options available, just depends on how many $ you wish to spend.  Just remember if you spend Cheap you'll get a Cheap Product and a Cheap Job, the reliability and longevity of the installation will reflect this.
One option is to go with a Remote Control and fitting Units to the outlet or you could go full blown C'Bus or to a DDC System.
Simply switching an appliance on to turn another off sounds a problem without modification of the appliance.  Which appliance takes priority?
Anyway, back to the 4th paragraph.  Tease1
Post  blur1 Tue 05 Aug 2014, 7:12 pm
Bad day hey Russ? lol!
Post  The Zodiac Tue 05 Aug 2014, 10:08 pm
blur1 wrote:Bad day hey Russ? lol!
Just another cranky electrician.......  Shocked   lmao lmao lmao
Post  Rusty62TransAm Wed 06 Aug 2014, 12:31 pm
Sorry, forgot to write "Joking!" at the end.   Moon2 BlowRasp1 Tease1
What you don't know is that Jeff has given me the details and I have suggested a potential solution. Everyone is Happy!  Respect1
