Rusty's HJ 1 Tonner Project.
Post  Rusty62TransAm on Tue 03 Feb 2015, 12:20 pm
This is my Tonner not long after I bought it and started stripping it down.
It belonged to a Roof Tiler.  Had Sand in all sorts of strange places.
Re: Rusty's HJ 1 Tonner Project.
Once I stripped it down I ripped out the 253 and 4 Speed.
Post  Rusty62TransAm on Tue 03 Feb 2015, 12:24 pm
Stripping it back for grinding, sand blasting and 2-Pak.
Post  Rusty62TransAm on Tue 03 Feb 2015, 12:25 pm
In the Shed, awaiting attack.
Post  blur1 on Tue 03 Feb 2015, 9:18 pm
should do the ej in the background of pic 4. lol! gone
Post  Rusty62TransAm on Thu 05 Feb 2015, 12:23 pm
blur1 wrote:should do the ej in the background of pic 4. lol! gone
What's there to do?   sad1
It's all done:
HR Disc Brake Front End
EH Bonnet
202ci c/w 350 Holley, Cain Manifold and Extractors
T-Bar, 3 Speed, Traumatic
High Back Bucket Seats
Extra Gauges Cluster
Stereo
Mag Wheels 13" on front 14" on rear.  Changed Kidneys to Hotwire 8" wide on back, 7" on Front.
Centre Mount Aerial
XE Front Bumper
Concealed Fuel Filler with Flap (Factory)
Lovell Lowered Front Springs
Blacked out Door Window Frames
Functional XA GT Bonnet Scoop
Cyan Blue Finish on inside and Headlight Surrounds
Grey Primer finish on the exterior.
Keyless Boot Entry - Screwdriver required.
PURFECT SLEEPER CREEPER!
Post  Rusty62TransAm on Thu 05 Feb 2015, 12:28 pm
Ps. Can be driven at 110km/hr until you run out of Fuel quite comfortably. lol!
Post  blur1 on Thu 05 Feb 2015, 2:50 pm
110?
i'm down to 92-93 k.p.h. sad1
Post  Rusty62TransAm on Thu 12 Feb 2015, 5:26 pm
Cleaned up all the welds and Primed them for good measure until I get around to Sandblasting the Chassis.
Decided I wanted the Spare Wheel in the middle and Exhaust Pipes running up each side, so I made a new Piece and welded it in after cutting out the original one and cleaning up.
Used an old Engine Stand I had and made something to use at the Front.  Viola!  A Rotisserie.
Post  Rusty62TransAm on Thu 12 Feb 2015, 5:38 pm
Also decided I want to be able to drive long distances and be able to pull up at the Bowser and not worry about which side to Fill from, so I've fitted Brackets for a Fuel Tank on the Left-hand Side. There's already a Factory Hole on the Chassis Plate, perfect for a second Filler Neck to go through.
Fuel Tanks were sent off to have crossover and balancing fittings added.
If you look closely at this pic, you can see the second set of Mounting Brackets.
Post  Rusty62TransAm on Fri 13 Feb 2015, 1:03 pm
Decided to fold up and fit a new rear Bar without all the Superfluous Holes and Notches.
Plan is to fit LTD Taillights anyway.
Post  sinbin on Fri 13 Feb 2015, 2:07 pm
Looks like you have a project on your hands Rusty.
Lots of fun planning and doing. One day you might put this effort into a Van cheers
So are we thinking Midnite Spares styling here?
Post  Rusty62TransAm on Fri 13 Feb 2015, 5:55 pm
Sadly, one of the problems (apart from the Ball & Chain crazyp ) in getting a Project Van is that I haven't found anything half decent where I don't have to take out a 2nd Mortgage and sell my Organs to put down a Deposit. sad1 Sad
Throw a Mattress on the back of a Tonner and you can make Love under the Stars. lol!
Kept the Front simple: HJ-Z Statesman.
Would Love to build a TransAm Tonner one day, with either a T-Roof or Gullwing Doors c/w T/A Interior and Massive Wheels on the Back. One day.
Post  Rusty62TransAm on Fri 13 Feb 2015, 5:57 pm
I do have my Lotto Ticket in though. Fingers Crossed! bagofmoney
Post  Rusty62TransAm on Wed 18 Mar 2015, 12:29 pm
Bought a Long 308 for it and sent it off to the Engine reconditioners. Block was cracked, so bought a short.
Fully reconditioned, new rings, new bearing, new valves & seat Grind, Lumpy Bump Stick, Hi-Volume Oil Pump.
Painted it in 2-Pak Mint Julip and Sherwood Green (metallic) before I put all my Goodies on it.
Machined the Flywheel and fitted a new Clutch and Pressure Plate for the 4 Speed.
Post  Rusty62TransAm on Wed 18 Mar 2015, 12:35 pm
Bought a new Edelbrock Torker Square Bore Manifold for it and a 650 Double Pumper Holley.
Bought a new set of Pacemaker Headers for it and sent them off to be Aluminium Sprayed.
Painted the Gearbox and Bellhousing to match the 308.
Post  sinbin on Wed 18 Mar 2015, 1:24 pm
All happening by the sounds of that Rusty.
Where's the pics? Also forum banner is missing.
Post  Jezebel on Tue 28 Apr 2015, 10:00 pm
Awesome work rusty! I love your rotissarie! Im sure yours will serve vavaluable inspiration when i come to that stage of restoration Smile
Looking forward to more updates
Jezebel
Jezebel
Post  Rusty62TransAm on Mon 30 Jan 2017, 10:39 pm
Sorry Guys, I sold it unfinished. Crying or Very sad Priorities changed.
I do have some more pics when I find where I stored them. pics lol!
