HELP NEEDED WITH ELECTRICAL ISSUES
Post  Mully on Wed 20 May 2015, 2:31 pm
Beep1 rubbish  PIECE OF  Beep1 WOOPSIES (being polite here. Thanks Admin)
My pilot car, a 4L XH Ford has a major electrical problem.
It shut down whilst being driven a week ago and now won't start.
It is getting an electrical pulse for a few seconds and then nothing.
We've changed relays, distributor and ignition module all without resolving the problem.
Checked all fuses too and they're all ok.
Apart from buying a gmh does anyone have any ideas PLEASE?
Sam has already suggested BURNING IT.
Re: HELP NEEDED WITH ELECTRICAL ISSUES
Post  sinbin on Wed 20 May 2015, 9:59 pm
Those Falcon sixes cook coils. They heat up and hairline crack and from that point on your knackered.
Change the coil and see if that gets the old bus going!
Post  blur1 on Thu 21 May 2015, 12:04 am
Yeah, my el wagon cooked a coil so i got a longer coil lead and a new coil and mounted it up higher in the engine bay away from the heat in the stupid place ford mount it.
mines now near my shock tower.
pull your coil lead mully if you can and crank the engine and see if you have spark?
if not change the coil.
Post  robleo on Thu 21 May 2015, 10:17 am
Try the BCM (Body control module) located just right of centre of the lower dash. It has the smartlock etc. and are known to fail.
Some times an old fashion give the dash a belt works.
Rob
robleo
Post  blur1 on Thu 21 May 2015, 11:28 am
and are you sure it's not a fuel pump/fuel issue?
and if worst comes to worst and you have to tow the car to a good mechanic, i highly recommend lakeside automotive in reservoir.
good luck with it all mully and keep us updated.
Post  blur1 on Sat 23 May 2015, 2:25 pm
Guess it's all fixed now?? Shocked Question
Post  panoz78 on Tue 30 Jun 2015, 10:09 pm
Hey Mully
What ended up being the problem with the work van ? crazyp
Post  Mully on Wed 01 Jul 2015, 9:09 am
Beep1 rubbish crap.
Still not going. Short of replacing engine everything else has been changed.
Post  panoz78 on Wed 01 Jul 2015, 9:44 am
Well what can I say
Except for maybe it's time to find a new mechanic/auto sparky that wants to/knows how to
fix the ford with out a box of matches.
There's only two things that will stop it from running, fuel & spark  so it carnt be getting one of them.
aa
Post  blur1 on Wed 01 Jul 2015, 11:34 am
Quote: "and if worst comes to worst and you have to tow the car to a good mechanic, i highly recommend lakeside automotive in reservoir."
Post  Mully on Wed 01 Jul 2015, 3:10 pm
Got a phone call from the mechanic just now. was a wire on gas system that was allowing gas to prime into converter but not allowing fuel into injectors. That was how it was explained to me anyway.
Post  blur1 on Wed 01 Jul 2015, 6:26 pm
nice mate, hope it's up and running again soon. thumbsup
b.t.w, got that business name/address about those led globes we spoke about?
