M20 impala shifter?
M20 impala shifter?
Post  fc59 on Wed 15 Feb 2017, 5:31 pm
G day shirts n skirts I have acquired an impala shifter off of an m20 I did a google didn't find any Intel on it any help would be appreciated
Re: M20 impala shifter?
Post  fc59 on Wed 15 Feb 2017, 5:38 pm
Post  fc59 on Wed 15 Feb 2017, 5:42 pm
Post  sinbin on Wed 15 Feb 2017, 11:14 pm
What did you need to know Dean?
Impala were typically an inline shifter not "H" pattern.
They advertised heavily in the 1970's and 1980's in magazines like CV&T etc.
Post  fc59 on Thu 16 Feb 2017, 7:50 pm
sinbin wrote:What did you need to know Dean?
Any more information would be appreciated Dr google didn't give me any answers
I was just having a play with it trying to work it out old mate who I got it off said it was a H pattern I haven't bolted it to the spare box yet so I don't know it's missing a few linkages or pins I think nothing I cant replace
So if its an inline shifter I'd imagine all the way foward is first
back is second
Third is Back or foward?
Post  blur1 on Thu 16 Feb 2017, 8:44 pm
it does look like it is a inline shift.
back in 1980 i had a similar shift on my m20.
it was a 'mr gasket vertical gate' shifter.
it had the main shift arm and 2 siamese rings you put 2 fingers into to pull up to ram the shift into reverse.
the 4 forward gears were from my ageing memory. forward 1st, back 2nd forward 3rd back 4th.
i wish i could find another one of those shifters. i loved it.
Post  fc59 on Thu 16 Feb 2017, 9:07 pm
blur1 wrote:it does look like it is a inline shift.
Ok cool ill bolt it down tomorrow see how it goes I dont know if it will fit with the console I made
Post  Blue Victor on Sun 19 Feb 2017, 8:23 am
"Ok cool ill bolt it down tomorrow see how it goes"
Just be careful, I note it says "professional shifter" on the side.......make sure you have the correct accreditation to use
Blue Victor
Post  fc59 on Sun 19 Feb 2017, 9:56 am
Blue Victor wrote:"Ok cool ill bolt it down tomorrow see how it goes"
dont worry ill cover that with the shifter boot Razz
Post  fc59 on Sun 19 Feb 2017, 10:31 am
ok so i gave it a quick clean pulled it open and there is a lot of sand / grit mixed in with the grease it has a bit of wear on the selector this plus the grit i think was causing the gates to jamb together
Post  fc59 on Sun 19 Feb 2017, 2:55 pm
I completely striped it i found two shims on one side on the selector none on the other side this wouldn't have been helping the jamming of the gates gave it a quick debur a wipe clean and a smear of grease put it backtogether and she's done
Post  sinbin on Sun 19 Feb 2017, 11:56 pm
Here is the Impala Shifter Advert that was common through the 70's and 80's.
Post  fc59 on Thu 02 Mar 2017, 9:20 pm
Cheers smooth for finding that ad
I have a complete m20 on loan so I can build the linkages that I'm missing and ill rebuild a set to fit a standard m20 shifter as well while am at it the ones I made for the old mans 3 speed feel nice
Post  The Original Birdman on Sat 10 Jun 2017, 8:49 am
Hi Dean,
If you sorted it out I have one too, which I'm going to use, it looks to be in real good condition. will trial fit this weekend on m21 I have.
Then will need to learn how to use the bloody thing LOL
Post  The Original Birdman on Sat 24 Jun 2017, 12:33 pm
Hey Dean,
Did I mention that the Impala shifter is for a three speed not a 4 speed. I believe they did make one for the 4 speed Muncie and Saginaw but not the Aussie 4 speed. I had forgotten about it and hence the reason I never fitted it to my van. Originally had it on my torana which was a column shift 3 speed till I fitted the inline impala. I had forgotten all about it seems like it was so long ago, well at least 36 years ago. LOL
Post  fc59 on Sun 25 Jun 2017, 4:00 pm
G day rob no you didn't mention that but your one and mine have different numbers stamped on the bottom that might be a model no not a serial no
That could be why yours felt different
