Best way to build speaker boxes
Post  Imperfection on Thu Oct 28 2010, 15:33
I have two 12" bass speakers, that i have to build speaker boxes for.Any hints on building them eg,timber MDF v fiberglass, thickness shape height ect.
James
Re: Best way to build speaker boxes
Post  Dean on Thu Oct 28 2010, 17:26
Spent a few years doing car audio in my spare time when i was abit younger. I used to use 10mm mdf and for 2x12" subs, an enclosure of about 60-80ltrs. Too large or too small an area and they wont have the punch. Vent ports are available at supashit. And speaker carpet(the stretchy stuff) can be bought from any car audio installer.
Dean
Post  MajesticXX7 on Thu Oct 28 2010, 20:24
MDF is good for standard boxes. If you want a more organic look you go for glass.
There are enclosure size calculators online. Different cars will have their own resonant frequency and you need to set things up to suit that for best sound. There are heaps of books around for setting up systems, but if you just want it in there without the messing about you build a box out of mdf.
MajesticXX7
http://www.hubgarage.com/mygarage/RodNResto
Post  serendipity on Thu Oct 28 2010, 21:35
make a template from thin plywood, cover it in vas, glass over it, remove the plywood, smooth it and paint it in your fav color, whallahh!!!
Post  MajesticXX7 on Thu Oct 28 2010, 22:03
http://www.termpro.com/articles/buildbox.html
MajesticXX7
Post  Imperfection on Fri Oct 29 2010, 09:32
serendipity wrote:make a template from thin plywood, cover it in vas, glass over it, remove the plywood, smooth it and paint it in your fav color, whallahh!!!
I'm only the cutter-outer my son is the glasser,as that was his job.Building racing yachts.till the company went under.So he should be able to knock some up for me Laughing
