Building boxes for the rear of your van.
Building  boxes for the rear of your van. Empty Building boxes for the rear of your van.
Post  Imperfection Mon 18 Jun 2012, 4:35 pm
I'm just about to start building the side boxes,whats the best base material,to build the frame out of steel or wood.I was going to use 1"/2" pine to build them ,but i thought i might buy some 1/2 in square tube and weld the frames up.Anybody used steel instead of wood,i think the benefits of steel is you can shape it to what you need. For all them strange angles,
Building  boxes for the rear of your van. Empty Re: Building boxes for the rear of your van.
Post  Jonny James Mon 18 Jun 2012, 5:50 pm
Half inch angle sounds like it would suit your needs.
Cheers Jon
Post  fc59 Thu 21 Jun 2012, 8:53 pm
depends what are you better at welding or joinery ?
Post  Imperfection Fri 22 Jun 2012, 8:40 am
fc59 wrote:depends what are you better at welding or joinery ?
I'm no good at ether,but $14 for 6mtrs of steel v $5 a mtr for wood.Steel looks good Laughing
