Wheel reboring
Wheel reboring
I just bought a set of ol school wheels for my escort, and the guy was a bit iffy on the pcb.he said that it was 108 but after FreeMason picked them up, the guy sent me a message saying that they were 120pcb.So i was wondering if i could get them welded and rebored.
james
james
Re: Wheel reboring
Found out the answer, hope the guy is wrong about the pcb
Re: Wheel reboring
Gidday James
I was going to say I don't think you would be able to Weld them without a LOT of Trouble.
I thought maybe you could have them drilled to be a Multi-Fit, but only if the Mounting Flange is suitable. e.g. it would need to be one solid piece; not stepped in the casting behind. Solid right through where the holes go. Hope that makes sense.
Good Luck!
I'll keep my Fingers Crossed for you.
Good Luck!
Re: Wheel reboring
The seller really should of checked to make sure what the measurement was even before you paid for them James,all I can suggest mate if they don't fit is to see if you can get your dollars back mate as he is the one that stuffed up or polish them up and make back your dollars and a little bit more.
Re: Wheel reboring
Thats what i'm thinking of doingBowtie383 wrote: polish them up and make back your dollars and a little bit more.
