Bigger alternators
+7
wizard1
Wizard429
samin8r
11 posters
Bigger alternators  Empty Bigger alternators
Post  Imperfection Mon 31 Oct 2011, 7:05 pm
Is it worth running one,as the one in the van is a bit sad 35amp. Sad So i found one on flebay its 70 amp, so with all the stuff i'm running amps brighter lights ect ect,would it be a good idea. scratch
Bigger alternators  Empty Re: Bigger alternators
Post  The Zodiac Mon 31 Oct 2011, 8:25 pm
I would, but that's just me. Wink
Post  agro Mon 31 Oct 2011, 8:38 pm
You can never have a "too big" alternator.
If it fits, then yes!!!
Post  samin8r Mon 31 Oct 2011, 9:28 pm
For Sure!!! My Prem had a 35A and I swapped it for a 70A. Especially if your running extra goodies!
samin8r
samin8r
Post  Wizard429 Mon 31 Oct 2011, 10:20 pm
running a bigger alternator is an absolute must. If you run a load of power draining devices - you will notice the difference. I ran a huge one on mine - it was at least 70A. may have been a bit higher - it was a special wind the auto elec did for me as I had lots of equipment that needed lotsa power
Fuzz
Wizard429
Wizard429
Post  wizard1 Tue 01 Nov 2011, 10:14 pm
we have fitted a 100amp chrome one and also fitted a gilmer drive it seems to keep everything going with what we have in the van, thanx wizard
wizard1
Post  Wizard429 Fri 04 Nov 2011, 8:12 pm
hmmm
chrome 100A - gilmer drive. Not many of those around.
sounds like the one I had
Wizard429
Wizard429
Post  Rusty62TransAm Sun 06 Nov 2011, 8:59 pm
I fitted a 100Amp one to the Wagon 30 odd years ago to run the Aircraft landing lights and the Stereo.
I had the cooling fan on it Chromed. If I rev it too hard the Blades start to straighten out. scared2 lol!
Hope that you don't have that problem. Sunny Wink
Post  wizard1 Mon 07 Nov 2011, 8:35 pm
not sure if you are talking to me but our alt came with a chrome fan it seems to work and charge ok just under 14 volts on the digital volt gauge thanx wizard
wizard1
Post  Jonny James Mon 07 Nov 2011, 8:53 pm
wizard1 wrote:not sure if you are talking to me but our alt came with a chrome fan it seems to work and charge ok just under 14 volts on the digital volt gauge thanx wizard
How much time has it spent passed 7000RPM?
cheers
Jon
Post  adrenaline Sat 14 Jan 2012, 10:43 pm
Rusty62TransAm wrote:I fitted a 100Amp one to the Wagon 30 odd years ago to run the Aircraft landing lights and the Stereo.
Arnt air craft landing lights HID and use less power thererfor reducing aroeplane weight by smaller baterries and alternators.
adrenaline
Post  fc59 Mon 16 Jan 2012, 5:13 pm
i have 8 power sockets on my hilux plus a big stero FOR A SINGLE CAB and 2 anderson plugs in the tray for running fridges and 4 masive halogen spotlights two up front and two as reversing lights and as well as fitting a big alt having a good bat that cant take the charge is a must
i run an optima in my hilux and when i rewire bluEJay ill fit one to that as well and im considering running a dual battery set up in the van also running big enough guage wire to every thing help with voltage drop with brighter lights better running equipment
in the bluEJay for example i have over a 1.5V drop from the battery to the voltage guage that is wired in to the fuse panel but i dont have any from the battery to the starter solinoid [that is where my loom begins] because im rumming 5 strand copper wire that is used in power transformers
Post  Rusty62TransAm Tue 17 Jan 2012, 7:11 pm
Gidday
No HID 30 years ago.
All Element. A heavy duty Relay and Wiring, Fused direct from the Battery for each light.
Post  magnum500 Wed 25 Jan 2012, 7:39 am
Some of the cheaper chrome alts have only one bearing and they fail.i use James from switched on for Elecs and he has fitted the bigger commodore style alt and no probs at all.jw
magnum500
magnum500
Post  Rusty62TransAm Wed 25 Jan 2012, 12:12 pm
magnum500 wrote:Some of the cheaper chrome alts have only one bearing and they fail.....jw
Nasty! Evil or Very Mad
