HQ Holden Dash Options
Did the HQ have the largest Range of Dash Options?
I think that maybe it did.
The GTS Dash also available as Option U21.
There were also two (2) other Options not shown:
U16 which was a Speedo, Large Tacho and a Small Fuel Guage in the centre where the Emblem/Clock goes.
UDI which was a Speedo and a Large Combo Fuel/Temp/Oil Guage.
Today's Lesson was kindly brought to you by GMH.
Re: HQ Holden Dash Options
Was there one of the HQ monaro releases that had the small monaro script badge to the right there the prem script is on the other one?
Max_Van wrote:Was there one of the HQ monaro releases that had the small monaro script badge to the right there the prem script is on the other one?
If I remember correctly, I would say you are correct.
I think that there was also a HQ LS Monaro. I'm not sure what Dash it had.
Yea, the LS has the monaro script with the LS a little larger at the end. Only reason i ask is the monaro in mad max has the script on the dash. It's a base model monaro not an ls, as it has the rubber floor mat etc.
Max_Van wrote:Yea, the LS has the monaro script with the LS a little larger at the end. Only reason i ask is the monaro in mad max has the script on the dash. It's a base model monaro not an ls, as it has the rubber floor mat etc.
Rubber Floor Mat is interesting. I'm sure you are right about the Dash Script.
I have an LS Monaro Boot or Front Guard Badge at home. It also has the LS larger than the Monaro.
» Two post hoist options?
» Bench seat options
» Pin for HX upper tailgate hinge. Replacement options???
» Mad Dash to Hervey Bay Van In
» DASH'S + DOOR TRIM SHOP
