IGNITION PROBLEM ,, POINTS TO ELETRIC
Hi all can anyone spare any knowledge on distributors ,,, (ford cleveland ) i have taken the points dissy out and replaced it with a stock ford electric ignition dissy ,,but have no spark at the dissy to plugs ,unsure if wired wrong , two wires coming out of new dissy ,, any help would be appreciated cheers col
Re: IGNITION PROBLEM ,, POINTS TO ELETRIC
If it's an EBAY one, be careful. Have seen module issues on Brand new ones.
They usually have 2 wires coming out. Red to + on coil & Black to - on coil.
agro- Majestic Vanner. Proud, Passionate and Paid Up!
What are the colour of the wires please ?
If it's bosch there should be one pink ,one green
The pink one has to go to the key & HAVE 12v WHILE IN THE CRANKING POSITION & POSATIVE OF THE COIL
green goes to the NEGETIVE OF THE COIL ONLY
Ymay have another wire to the negative of the coil for the factory tachometer ..
Make sure you are using a electronic ignition coil (they are completely different).
Thanks for the input ,,, only have a red and black wire the coil is a GT40R ,,How do i tell if its compatible ? cheers col
I've got a WB dizzy in my HZ. Still have the original resistive coil on it as well.
All i did was to put:
a) the black to the negative side of the coil.
b) leave the resistive wire going to the coil.
c) have a 12v supply to the red dizzy wire.
All works great.....SO FAR!
Spot on Agro , took me a minute to change running good now , cheers col
Bosch coil GT40R is designed to be used with a resistor that drops the voltage
to 9 volts (better for points).doesnt burn the points as bad.
GT40 coil is for 12 volts (Electronic ignition)
Cheers Neil & cherone have swapped it for a GT40 and it does sound better cheers for the heads up col
» ignition switch connector
» 2 Points about putting down-lights in your van
» I hate dizzy's with points
» Head problem on 350 Chev
» Power Steering conversion problem!! need advice !!
