after market lower tailgates
Ramble
has anyone had one of these and are they a good fit? just bare metaled mine and it has serious tow bar dents and rust issues, cheers
Re: after market lower tailgates
I have one about to fit it up to the HJ van.
Doesn't feel as thick as an original gate. But looks as though it should bolt up ok.
Think Rob fitted one to his HZ sandman ute.
Cheers Jon
Cheers Jon
Ive got one fitted to to my van Ramble. It fitted up with no issues. Is a bit lighter but you still get that heavy holden "thump" when you close it so Im pretty happy with it.
All the fittings and hinges bolted up with out much trouble.
Hope my experience helps your decsion.
Ramble- Newbie
thanks, for that, i just want one that fits the original lines
the one i put on our van was a taiwanese one which had to be modified because it was a ute one but in saying that everything else lined up thanx wizard
wizard1- Part of The Furniture
might go with it then, thanks for the advice, cheers
Just out of interest wizard, what has to be modified as I've heard this before?
Yea they fit fine. Have to notch the corners to suit van. Be careful though as the injury to my fingers was as a result of the edges not being rolled over properly and they are razor sharp.
i remember the injury troy, but they are sounding better than the pile of crap i have here
It's a 1 inch by 1 inch square that you have to cut out of the top outer corners to clear the rear pillar area.
You can see it on the upper left of the gate.
Seen better on this pic.
Cheers Troy.
Yeah as SMQQTH said I fitted one to my old white Sandman ute, not as heavy or solid as the originals but went on well with no issues at all.
» look whats on the market
» After market rubber seals....
» After market rubber seals.... are they any good....?????????
» What Would You Pay for a HJ-Z Statesman Lower Grille?
» My chain block wont lower
