Retrieving engine no's
Just looked at my engine,when they decked the block they sort of removed the engine no.And we have no idea, what to do as i have no rego papers.With the numbers on it, i'm up that well known street.I rang the engine builder, he didn't know he did it and cannot help.Any ideas
james
james
Re: Retrieving engine no's
Gidday James
Sounds like a job for CSI. LOL!
I did hear once that when a Number or Letter is stamped into metal that it distorts/bruises the molecules beneath and that if it was ground off that there was some scientific way of retreiving it. It might have been by applying some sort of etching acid.
But I honestly don't know.
It will be interesting to hear if it can be done and how.
Pity its not as simple as the Pencil on Paper Trick.
Good Luck!
Good Luck!
I "Googled" thisfrom a Ford Forum:
"if you have no number there take a closer look to see if on area it
should be it has been ground off with angle grinder or if someone has
used a carbide burr to remove number .
the actual number can be retreived with specialist eqpt used by police
if no engine number is there then chances are the engine is a ringer ,
it could be a recon engine but usually they would display the orignal
number they came with from factory , none of the remanufacturers would
usually remove and engine number for a reason other than it was a
little chaud ."
little chaud ."
I've heard they x ray the block and retrieve it that way.... similar to checking the block for cracks
Jon
Jon
Good ol ford, the engine no is the same as the chassis, no which is the same as the Vin number.
Well done James.
It was just tooooooooooooooooooooooooo simple.
» quick way to remove an engine
» Engine swap to non general motors product
» Engine dating
» Engine info
» Alloy 308 engine pulleys?
» Engine dating
» Engine info
