Electric Fuel Pump
Electric Fuel Pump
Hello MJ's,
I am looking at installing an electric fuel pump in my panel van but unsure of where, how and what type. Motor is a warm 308 with a holley 4 barrel carby. Any comments /suggestions would be appreciated.
Thank you,
Andrew
Thank you,
Andrew
Kalgoorlie Sandman- MAJESTIC VANNER, Proud, Passionate, Paid Up 2021!
Rusty62TransAm and Rohan like this post
Re: Electric Fuel Pump
Hi Andrew,
I just recently went through this with my HQ.
My high flow mechanical pump was leaking and it was starting to get worse. I tried to look at getting an overhaul kit for it, but they are hard to source, and pretty pricey to boot.
At the suggestion of a couple of members I went with installing a Carter electric pump, along with a Peel safety switch to power it. The Safety switch operates by sensing a pulse from the ignition coil, so that it only powers the pump when the car is running. It also powers up for 2.5 seconds to prime the pump when the the ignition is first turned on.
I have mounted the pump on the chassis above the tail shaft, and ran fuel hose from the tank outlet to the pump and back into the fuel hard line to the engine bay. It works really well and I am very happy with it.
Cheers, Karl.
Cheers, Karl.
Rusty62TransAm and Kalgoorlie Sandman like this post
Nice Job there Karl.
Kalgoorlie Sandman likes this post
Hi Rusty
Do you have any details of fuel system so I can get some prices.
Cheers, Andrew
Cheers, Andrew
Rusty62TransAm likes this post
Kalgoorlie Sandman wrote:Hi Rusty
Cheers, Andrew
Gidday Andrew
I'll have the details written down. I'll have a look on the weekend (or sooner) and get back to you.
Don't be afraid to remind me.
Thanks Rusty
Links to VPW:
There are a couple of different size Fuel Pumps available.
Carter Fuel Pump 72gph
Carter Fuel Pump 100gph
Fuel Filter
Similar ProFlow Fuel Filter 3/8"
Fuel Filter
Thanks Rusty
Kalgoorlie Sandman wrote:Thanks Rusty
You're welcome Andrew.
Do you recommend the 72 gph for a warm 308?
I'm not an expert by any means in this regards. The one on my Van appears to be the 72gph Pump, which has a 5.3 Litre Engine.
Karl looks to have the same one. Hopefully he will see this post and comment.
