fuel tank question
fuel tank question
i assume it will but someone might know for sure
i the stock petrol tank in a wb ute the same as in a WB panelvan?
Re: fuel tank question
Yep sure is
whyle uve got a tank out its a good time to fit an electric pump in there if ur going the injected route. i just modifyed the pick up to addapt a vs pump and drilled 2 wire holes in the sender plate but if i had the tank out i would run wires thru top of tank instead.(less sealing issues) i have the engine bay side of an lpg setup from a vs ss if ur intrested as well.i have some tanks aswell but thay were bigger than the sizes u were after. where did u want to mount tank?
bns454- Regular
what sort of tanks? LPG!bns454 wrote:whyle uve got a tank out its a good time to fit an electric pump in there if ur going the injected route. i just modifyed the pick up to addapt a vs pump and drilled 2 wire holes in the sender plate but if i had the tank out i would run wires thru top of tank instead.(less sealing issues) i have the engine bay side of an lpg setup from a vs ss if ur intrested as well.i have some tanks aswell but thay were bigger than the sizes u were after. where did u want to mount tank?
what size are they
looking for a 720 x 350
1x 880mm 2x940mm so there all to big for what your after but 1 0f the 940s was under my ute where the spare tire was ment to be like a drop tank
bns454- Regular
